Need Instrument cluster for Safari GQ TD42.
42south
Post by 42south »
Help needed. I’m about to be grounded when my WOF runs out due to a speedo failure.
Does anyone have an instrument cluster for the GQtd42. Years 1990-1994. With the yellow instrument markings.
Ill take one with faults if its the usual GQ faults of sticky movement or needs a tap to start. These faults can be fixed.
Phone or txt me 021 265 8878
Thanks guys
1991 SWB GQY60 TD42 safari.
DTS turbo kit.
42south
Re: Need Instrument cluster for Safari GQ TD42.
Post by 42south »
Hi Guys
I gave up in the end and took the cluster to Parrotts in Christchurch. Speedo issues solve by them fitting their custom speedo circuit board. There is a slight flicker but not an issue. It is adjustable, by them, to allow for different tyre sizes etc.
DTS turbo kit.
MihiT
Post by MihiT »
Good to know. Common failure. I think it's a zener diode that fails, which seems to be unobtanium now...
1989 LWB 5-Seat TD42
