High Steer Kits for Sale HILUX, 40, 60 and 70 Series
From lockers to air deflaters, if it has to do with wheels tires or axles, you can find it in here.
Moderator: Vendors
suzolla
Post by suzolla »
Hi,
I have got some Trail Gear RH drive Hilux complete high steer kits either with standard style bent pitman arm or flat pitman arms for sale.
Includes Trail Gear RHD Arms, 80 Series ball joints, heavy duty tie rod and drag link and pitman arm.
$525 plus freight from Hamilton.
High Steer kit should also suit 40 and 70 Series, tie rod should be the correct length, drag link may need to be altered, I can shorten if required.
Can do a cheaper version for $475 plus freight from Hamilton
Includes Trail Gear RHD Arms, 80 Series ball joints, tie rod and drag link are std 80 series ones cut to length and re-threaded and pitman arm.
And can do an even cheaper verson for $425 plus freight from Hamilton.
Includes Trail Gear RHD Arms, 80 Series ball joints, tie rod and drag link are std 80 series ones cut to length and re-threaded and an adapter on the end of the drag link so that you use your Surf pitman arm.
Also got IFS Steering Box Mounts if putting IFS box on Hilux $80 if bought with High Steer Kit. $90 if bought by its self.
PM me if interested.
Tim
jakwoo39
Re: High Steer Kits for Sale
Post by jakwoo39 »
hey there, i bought one of these kits from you a few months back (truck still not going) and i have just sat the pitman arm in place, not torqued up yet and it looks like the bent pitman arm is going to be an issue on it hitting the springs
so would yoube willing to swap me a flat one??
suzolla
Post by suzolla »
Yes, No problem.
Have sent you a PM
Tim
fisho
Post by fisho »
If you go high steer watch your sump clearance.I have rears in front and 50mm dropped shacles on front and rear of front springs.Still occasionally just touches sump so some longer bump stops may be needed.
J_Dub
Post by J_Dub »
Hi mate
how much for a straight pitman arm only?
Ive got a drop 1, but want a straight to experiment with to see which is best, then you can have back the one I dont use
suzolla
Post by suzolla »
Hi Jared,
Have sent you a PM
Tim
suzolla
Post by suzolla »
Bump,
See first post for details
Tim
suzolla
Post by suzolla »
Bump,
Tim
suzolla
Post by suzolla »
Bump,
Tim
suzolla
Post by suzolla »
Bump,
Tim
suzolla
Post by suzolla »
Bump
See first post
Tim
suzolla
Post by suzolla »
Bump
See first post
Tim
suzolla
Post by suzolla »
Bump
See first post
Tim
Only one of the full Trail Gear Kits left, plenty of the others.
surf10
Post by surf10 »
hay man do you sell just the hi steer arms?
suzolla
Post by suzolla »
Bump
See first post
Tim
Surf10 i have pm'd you.
suzolla
Post by suzolla »
Bump
See first post
Tim
None of the full $600 Trail Gear Kits left, plenty of the others. $545 and $475
suzolla
Post by suzolla »
Bump
See first post
Tim
pradon35s
Post by pradon35s »
hey mate. would you sell both the drag and tie rod, your cut down style ones with no tierod ends or ball joints? cheers
Yes, replied and done, cheers, Tim
suzolla
Post by suzolla »
Bump
See first post
Tim
suzolla
Post by suzolla »
Bump
See first post
Tim
suzolla
Post by suzolla »
Bump
See first post
Tim
suzolla
Post by suzolla »
Bump
See first post
Tim
suzolla
Post by suzolla »
Bump
See first post
Tim
suzolla
Post by suzolla »
Bump
See first post
Tim
suzolla
Post by suzolla »
Bump
See first post
Tim
suzolla
Post by suzolla »
Bump.
See first post
PM me if interested
Tim
suzolla
Post by suzolla »
Bump.
See first post
PM me if interested
Tim
suzolla
Post by suzolla »
Bump.
See first post
PM me if interested
Tim
suzolla
Post by suzolla »
Bump.
See first post
PM me if interested
Tim
suzolla
Post by suzolla »
Bump,
See first post
PM me if interested
Thank you
Tim
Return to “Axles Tyres and Wheels”
