Hi all. Got the chance to get a prado 95 rear axle to put into the 185 surf to get disc brakes. This one even has the load proportioning valve. What about needing the master cylinder and/or brake booster?
Has anyone done this? It;s my daily driver and tow wagon so I can't get into needing certs or anything. It's got to be reliable. The surf drum brakes suck, even when properly adjusted.
prado rear axle swap into surf info
- floatingkiwi
1999 KZN185W SSRG TJM T-15 Bar, Tigerz11 2speed winch, 2" EFS sus lift, 265-75R16 Engine guardian. Auberins EGT. LED light strips. weathertech cargo liner. Safari Snorkle SS145HF. Prado rad. Front and rear E-locker.
Re: prado rear axle swap into surf info
Cant help with what parts you may need but going to discs in the rear will require cert regardless
